[?]: connect MP777 to two CPU315 with software redundancy
PLC_ITA
Post by PLC_ITA »
Hi friend's, i have a system 2 cpu 315 2DP that are connected via mpi and have a redundancy software
Both the cpu are connected via profibus with ET200 and relative IM.
I need now to connect a MP377 panel but i haven't idea how to do,
because how MP377 know which Cpu is on line ?
Thak you
this is for CPU 400H
but you can try
How do you connect an operator panel (WinCC flexible) to an H system (S7-400H)?
http://support.automation.siemens.com/W ... n/22584322
I use this with MPI CPU 400H
Connecting an operator panel directly to an H controller via a "software solution"
http://support.automation.siemens.com/W ... n/23842653 (English)
http://support.automation.siemens.com/W ... t/23842653 (Italiano)
You can share Sowtware Redundancy soft to Rapidshare ?
