[?]: software instead quick designer to program proface hmi
asteroidehk
Post by asteroidehk »
Hello Friends
QuickDesigner export projects with .prj extension.
Can I open this .prj project with another software? Wich One?
Also, i have an pro-face hmi QPGCTDE0000 but, firmware it´s in chinese or japanese. :shock:
I want to change to english because is a big problem to undestand when I go to hmi setup.
Quickdesigner can´t change firmware, wich software could do that?
Thanks in advance.
enrique_gf
Post by enrique_gf »
Hi have you tried this software?
http://plc.net.ru/viewtopic.php?t=5623& ... ht=proface
Saludos.
indian
Post by indian »
No.
Recently I worked around it because I had been forced to find out a replacement for discontinued QPK panels. I found out that "Proficy View" software is uploading QD's projects. (or, it is just make a porting?) Also new one panel is needed, anything like this - IC754VSI06. So, it is very costly update.
