[?]: Connect to an InTouch 6.0B through IAS 3.0 DIObject
pubmagy
Post by pubmagy »
Does anybody know how I can read data from an InTouch 6.0B using an IAS 3.0 DI Object, or other communication object that let me access to the data residing in an InTouch 6.0b?
bunglehead
Post by bunglehead »
InTouch provides tag data using SuiteLink protocol with application name == View, then use tagname as item name. You can use DI Object which knows SuiteLink.
Frank Liu
Post by Frank Liu »
InTouch 6.0b only provides tag data using DDE protocol with application name == View, then use tagname as item name. You can use DI Object which DDE.
