[?]: scada with VB
другие контроллеры
ansori
[?]: scada with VB
Post by ansori »
Dear friends,
I had try making scada with vb for omron plc and it work succes.
And I also have made some projects that use vb to controll and monitor omron PLC.
Next, I will have a project that same but using mitsubishi PLC FX2N with FX-232-BD.
I have read the communication manual and to applied.
But it doesn't work.
Why?
mech962784
Post by mech962784 »
Dear Friend
why don't you use the opc technology it is very simple to implement and more reliable than programming the communication,if you need more details i can provide you.
ansori
opc technology
Post by ansori »
what is opc technology (i'am so classic)????
pls explain me
Schtiel
OPC Technology
Post by Schtiel »
OLE for Process Control (OPC) which stands for Object-Linking and Embedding (OLE) for Process Control, is the original name for an open standards specification developed in 1996 by an industrial automation industry task force. The standard specifies the communication of real-time plant data between control devices from different manufacturers.
http://en.wikipedia.org/wiki/OLE_for_process_control
http://plc.net.ru/viewtopic.php?t=7715
ciwa
Post by ciwa »
For OPC you can use Kepware KepServerX or OPC Tunnel. Search this forum..
Ciwa
