[?]: How work software redundant ?
cemara
Post by cemara »
I am installing software redundant, after downloading i got this problem:
1. Both CPU in stop mode:
- at first IM153-2 SF blink, ACT off.
- at second IM153-2 every thing is OK, ACT on
- SF and BF LED at both CPU are off
2. Switch CPU to RUN mode:
- SF LED on at both CPU
Could anybody tell me what is wrong? i would like to attach my hw config and network picture along with my program. DiagnoseA.txt and DiagnoseB.txt are the event i recorded from diagnose buffer of CPU A and CPU B respectively.
But i do not know how to do it here. i could send by email, my email is cmr_asri@yahoo.com. i have bundle it into pdf file, only 291 kB. thank you in advance
Nedjeljko
Post by Nedjeljko »
...well..
...do you have make change in HW config!?
...do you dowload that changes to your CPUs?
...be careful with termination of your bus!
...good luck...and let us know :?
cemara
Post by cemara »
both of my hw config are the same
i have downloaded everything into both of my cpu
i have tested both termination of my bus.
still could not get it right
Nedjeljko
Post by Nedjeljko »
...put both CPUs in one single project...so you wil have single system data which will be stored to both cpus...
...maybe now happend that both cpus have adresses nr 2...check that
cemara
Post by cemara »
I got it,
My program only have 2 IEC function block. instead of writing 2 at IEC LEN in OB100, i wrote 8. after changing it to 2 everything is fine.
:lol:
Nedjeljko
Post by Nedjeljko »
:wink: :wink: yupiiiii
