i have project of wincc
i open bet i cannot simulate values and cpu tags
how i can do this
if i install plc simulator its work or not ??
any body have idea ??
[? +]: PLCSIM Simulation with WinCC
Operating S7-PLCSIM through WinCC RT
QUESTION:
How can I operate S7-PLCSIM (RUN-P, RUN, STOP and MRES) directly from WinCC Runtime?
ANSWER:
The function can be realized in WinCC without much programming.
Proceed as follows:
Start S7-PLCSIM
Open the Graphics Designer
Add a control object
Now select the object "Siemens.S/WSPanel.1" (Fig. 1)
see
http://support.automation.siemens.com/W ... n/11916587
QUESTION:
ANSWER:
Proceed as follows:
Start S7-PLCSIM
see
