I am new programming to hmi panel to working together plc, I using weintek 506 series touch panel and siemens s7 224 cpu.
Program is weintek own easymanager.
I make simple program where i try touch panel push button activated some output s7 224 cpu.
Is"t i must be some program first cpu or can i direct use hmi panel some outputs?
I try make simple program where is one input and one output, but that not work.
What i set step7-microwin if i set hmi panel one button Q1 and i want handle that cpu? Do i normal program block like I0.1 ----Q1 or is"t i must setting some communication command?
Can any help me starting programming my touchpanel?
