[?+]: More than 1 license of the same type is possible?
Scarch
Post by Scarch »
It is possible to store in the same hard disk, let's say, 12 licenses of Step 5.4 basis?
I can set only one, if I repeat the operation it says it already exists.
dibolo
Post by dibolo »
you are already answer your question.no.
only if you have some small partitions in the same hard disk you can copy them.
ALM v3 store licence keys with different serial numbers in one file
http://plc.net.ru/viewtopic.php?p=16875#16875
EKB View Plugin wrote:C:\AX NF ZZ\SIFLA1PLCS0504.ekb
Key name : S7-PLCSIM V5.4
Family : SIMATIC STEP 7
Version number : 5.4
Manufacturer : Siemens AG
License type : Float
Multi Keys file : Total 6 keys
Serial numbers : 00401000002008003015 ; 00401000002008003010 ; 00401000002008003011 ;
00401000002008003012 ; 00401000002008003013 ; 00401000002008003014 ;
