[?+]: keygen for Progea Movicon X11
wangrenzhi
I have Progea Movicon X11
I Need keygen for Progea Movicon X11.
deymon
emulator
keygen is bad way. algorithm will change in next build. need dump from hardware key for software emulation.
[dead] :/171040722/E ... ovicon.zip
Movicon 11 Rel. 11.0.1013 Oct 2008 .zip (504 Mb)
P.S. hmmm somebody (admin?) change my link and filename. it not Progea Movicon 11 key emulator. it only tools for make dump from Eutron SmartKey hardware key & make driver from dump (duplicate key).
deymon
i need dump from key 11 version for make full unlimited key
for example viewtopic.php?t=5740&start=15
send me in PM, please.
frankw
If you are using Movicon11, please use the tool
make a dump of the key, and upload it, thanks.
wangrenzhi
Movicon11 Rel. 11.0.1014
http://www.movicon.info/download/setup/Mov11_Setup.zip
Movicon 11 Build 1015 now available
Movicon 11 Build 1015 for Chinese
[dead] :/204638820/M ... ateCHS.exe
http://www.movicon.info/download/setup/Mov11_Setup.zipMovicon 11 Build 1015 for Chinese
[dead] :/204638820/Mov11_1015_UpdateCHS.exe-
wangrenzhi
Re: emulator
Hi deymon
Emul_key_for_Progea_Movicon.zip is Ver1.01
I have EuDMP V3.07,
[dead] :/208960968/EuDMP_V3.07.rar
How Will Make Eutron.dmp to Eutron.sys For V3.07?
think
I have EuDMP V3.07,
think
deymon
hi China brother
your link not work
direct link for this tool http://www.brstudio.com/Keys/eudmp.rar
it's different programs and compare versions not correct
your link not work
deymon
mech962784
Re: [?+]: keygen for Progea Movicon X11
Dear Friends
I have installed Movicon on a PC that does not have a Parallel port, so the license is not working and it is showing me that the serial number is 0.
does anybody have a solution for me?
DbIMok
mech962784: try install parallel port driver without real hardware.
McAlexU: for 10 only:
[dead] :/172725925/mov10m.zip
[dead] :/237614412/mov_drv_lic_code.zip
sometimes not working
Where i can find parallel port driver, so i can install it ?
Start - Control Panel - Add new hardware
Add new device - Manual - Ports - Parallel port
wangrenzhi
Vansdan
Hello
is there any crack/serial for Progea Movicon 11 available or just for version 10.x? At the moment I´m a little bit confused about the conversation in this thread.
Where can I find a crack/serial?
Thank you for your answer in advance
Vansdan
Vansdan
wangrenzhi
Movicon 11.1 Ver 1055.
http://www.movicon.info/download/setup/ ... _Setup.zip
Please Crack or Keygen Help me.
DbIMok
emulator for 11 at the end of this topic:
viewtopic.php?f=14&t=5740&p=37554#p37554
Movicon 11.2 Rel. 11.2.1083 Oct 2010 (620 Mb)
asgari64
Hello, I have Movicon ver 11.4.1151
I need key number for active it.
can you help?
can you help?
DbIMok
There is no common key for all. It is generated for a specific computer. Use the generator at https://only-soft.org/viewtopic.php?t=20186
mech962784
Anyone can share download link for Movicon Pro.Energy .NExT.
