[?]: I have my license corrupt
ausnis
Post by ausnis »
hi!
I need help with step 7
i have intall step 7 v5.3 in my laptop, now i install s7 sp3 and i lost my license, my old license is now corrupt,
i have the error c229,
do somebody know how i can recover my license?
i think that i need an activation code, it´s true?
i already use the program alm v3.0, but it said me that the license is corrutp, and when i check it the program said me that it is defective.
do you think how i can get the activation number without call to SIEMENS? or if exist other form?
tanks.
Contact:
For restoration of an original key you should call in Siemens support.
Official Repair and transfer programs for authorizing and licensing of SIMATIC Industrial Software
http://support.automation.siemens.com/WW/view/en/114358
If you do not have opportunity to call you can install a key from EKB_Install on other partition of a hard disk.
After reception of the answer from Siemens remove this key.
in Russian wrote:Для восстановления оригинального{первоначального} ключа Вы должны позвонить в Siemens.
Если у тебя нет возможности позвонить, то ты можешь установить ключ из EKB_Install на другой раздел жесткого диска.
После получения ответа от Сименса удалите этот ключ.
