Hello!
I planning make homecontrol system my home siemens simatic s7 224 cpu and some hmi panel.
My idea have i can set that hmi panel car heating on, inside temperature settings, connect my alarm system and info that, air system and many more idea.
But now i wondering what is best hmi panel that system and where best palce get those panel?
I order ppi usb cabel here: www.fractioni.com and there is some cheap hmi panel like Weintek HMI MT-506LV, but is that combatible whit s7 200 cpu?
And if you know some good links home automation whit siemens logic, i"m clad if you tell where is more good info.
I think maybe buy this panel: ftp://ftp.weintek.com/MT500/English/Doc ... aSheet.pdf
Is that good idea?
[?]: Homecontrol system and hmi panel + simatic s7 200
...hi...nice Idea..
I have plans for my home to, to make automation of all what I can put in automation.
But Im not search other panels than Siemens...do you have succes with this panel which you choose.
Im searching for some actuators which will be in Dimmer functions for lights, so when I press buton for example "Movie", all lights in livingroom will be Dimmed to minimum...
I have plans to make and:
...solar panel system for heating water, boiling room, cooling system, alarm system...
please let me know your progress in this work..
Can this be something for you?sahkari wrote:Is"t possible get work eib system and siemens S7 224 cpu? Do i need some adapter. If possible that help configure my homecontrol system.
"SIMATIC NET, DP/EIB LINK NETWORK TRANSITION PROFIBUS DP/EIB"
http://support.automation.siemens.com/W ... aller=view
