[?]: SFC V7.0 is not started
komatic
Post by komatic »
Hi all
I instal
Step7 5.4 SP3.1
CFC V7.0
IEAPO V7.0
TH V7.0
SFC V7.0
SFC is not started without any message :(
who can help me?
regards
chic-yong
Re: [?]: SFC V7.0 is not started
Post by chic-yong »
I found this problem, either. In s7 programming, the screen flick once, and after that nothing happened.
In D7-SYS programming, the SFC block can not define interface.
smb
Post by smb »
I have the same problem.Did you find any solution for it?
komatic
Post by komatic »
smb wrote:I have the same problem.Did you find any solution for it?
No problem still exist :(
smb
Post by smb »
How did you solve it?
komatic
Post by komatic »
Just use pervious version
smb
Post by smb »
Which version can I use?I checked by CFC and SFC V6.1,but it didn't work too.
komatic
Post by komatic »
smb wrote:Which version can I use?I checked by CFC and SFC V6.1,but it didn't work too.
Its sad, but only ver 5.2 HF4 works on my comp, i need it only for study and this is not big problem for me...
smb
Post by smb »
Where can I find SFC V5.2 HF4?Would you please upload it to rapidshare.
smb wrote:Where can I find SFC V5.2 HF4?Would you please upload it to rapidshare.
SFC 6.* from PCS7 6.* and D7-SYS
and SFC 7.0 from PCS7 7.0 work perfectly without problems
if no other problems in your PC (virus/antivirus and firewall).
smb
Post by smb »
Yes,I think it works,when installed in PCS7 not with STEP7.It seems,it needs anothor software for working with SFC,I have to install something else in PCS7 which isnot in STEP7.
