Hi.
The version 2.0 uses a USB dongle.
Is there anyone who knows how to crack the program?
I don't have the usb dongle, only the trial version.
I've uploaded the trial version:
[dead] :/99022317/Om ... .part1.rar
[dead] :/99019286/Om ... .part2.rar
I hope this can help.
Thank you in advance.
[?]: CX-Supervisor 2.0 crack for USB dongle
alfonsoad
mech962784
Dear most
i have version 1.2 activated and well functioning.
then i follow your suggestion and installed version 2 on top of 1.2,it will uninstall 1.2 automatically.then when i use CX-supervisor runtime it will give eval 30 days.
so i advanced my PC clock beyond this 30 days and the runtime will give 2 hours demo.
are you sure that the old token will work for the new version.
Best regards
Best regards
vlad2006gr
cx developer 2.0
Dear most.
Please upload and replace files.
[dead] :/101402793/cxdev.rar
Remove trial, remove usb dongle.
I am a testing on CX-simulator. Please testing on real device and send final result.
Good luck!
Good luck!
mech962784
most
2 updates for supervisor for trial version of alfonsoad
[dead] :/103987262/C ... _.rar.html
2001-0000-2070-8472
(install with out cr@ck)
most
2001-0000-2070-8472
most
vlad2006gr
Hi most.
Run regedit. Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\
Find CX-Supervisor.
Replace "Version"=dword:02000000 on "Version"=dword:020a0000
Run update 1.
Replace "Version"=dword:020a0000 on "Version"=dword:020b0000
Run update 2.
Only without SN runtime update.
See old, new1 and new2 reg files.
[dead] :/104536325/reg.rar.html
Find CX-Supervisor.
Run update 1.
Run update 2.
drifter
Does this work on Windows Vista?
I'm just saying because i eard that CX-Supervisor 2.0 is not compatible, but 2.1 is.
So, installing 2.0 with the crack posted here, and updating to version 2.11.2 like vlad2006gr said will it work?
Just wondering if anyone already know this.
I will try it tomorrow at my home PC
.eof
.drifter
.eof
.drifter
vlad2006gr
Hi most!
Thanks for SN.
-------- trial 2.0 + update 2.1 ---------------
Resume:
1.Install trial 2.0
2. Run cx1.reg
3. Install update 2.1, Sn 2001-0000-2070-8472
4. Run scs.exe
Open project and message: "Software protection not found. External communication will be disabled."
Download [dead] :/104864957/patch2.1.exe.html
Place in folder CX-Supervisor and run.
Communication enable. Please testing. Only for version 2.1.
--------- update 2.11 ---------------
Sequential.
1.Install trial 2.0
2. Run cx11.reg
3. Install update 2.11
4. Sn 2001-0000-2070-8472
!!!! Only select Repair (is not Modify)!!!
5. Download [dead] :/104913325/p ... 1.exe.html
Run patch.
Please testing. I have is work on cx-simulator.
Enjoy!
http://depositfiles.com/files/5050815
http://depositfiles.com/files/5051544
http://depositfiles.com/files/5051955
http://depositfiles.com/files/5052412
http://depositfiles.com/files/5053029
http://depositfiles.com/files/5053293
Thanks for SN.
Resume:
1.Install trial 2.0
2. Run cx1.reg
4. Run scs.exe
Sequential.
1.Install trial 2.0
2. Run cx11.reg
Run patch.
Enjoy!
not rapidshare link, only english version!in Russian wrote:Для русскоязычных пользователей.
Работают все версии 2.0, 2.1 и 2.11.
Для получения версий 2.1 и 2.11 после запуска рег файла и ввода серийника выбирайте при установке сначала repair, потом повторно установите с опцией modify.
Т.к. это не обновления старых версий , а хотфиксы этих-же версий.
При репаир восстанавливаются основные файлы, при модифицировании обновляются драйвера и часть второстепенных файлов.
В любом случае, после установки, проверьте у девелопера и рунтайма версии.
Они должны соответствовать номеру обновления.
Только помните, что в эти обновления весь дистрибутив не запихают, чем-то могут отличаться.
http://narod.ru/disk/190739000/Omron_CX ... .part1.rar
http://narod.ru/disk/190815000/Omron_CX ... .part2.rar
Все патчи в одном архиве
http://narod.ru/disk/190621000/CX-Super ... dongle.rar
Удачи!
most
runtime for cx supervisor is a part of cx supervisor, it is in the trial version.
install cx supervisor and use the serial number for developer and the patch by vlad2006gr to break the runtime protection.
ok I perceived the intention
i have disk runtime 1.3 and some updates, if you want this version
but you can try this:
my runtime have this files (with out lic):
bc500rtl.dll
bwcc.dll
BC450RTL.DLL
BWCC2.DLL
cxsupervisorres.dll
Cc172mov.dll
Czech.lnd
Czech.lng
dbghelp.dll
Danish.lnd
Danish.lng
Data Log Viewer.GID
Data Log Viewer.HLP
Data Log Viewer.ocx
Deutsch.lnd
Deutsch.lng
DONGLE.EXE
DONGLE1.DLL
English.lnd
English.lng
ErrorConvert.exe
Español.lnd
Español.lng
Finnish.lnd
Finnish.lng
French.lnd
French.lng
Greek.kbd
haspdinst.exe
hldrv32.exe
HARDLOCK.SYS
HLINST.EXE
HLVDD.DLL
Italiano.lnd
Italiano.lng
Nederlands (België).lnd
Nederlands (België).lng
Norwegian.lnd
Norwegian.lng
OWL1A.DLL
Polish.lnd
Polish.lng
Português.lnd
Português.lng
ReadMe.htm
RemoteLogView.exe
Russian.kbd
Russian.lnd
Russian.lng
scs.exe
scsrunps.dll
SCSDEFS.KBD
Slovenija.lnd
Slovenija.lng
Swedish.lnd
Swedish.lng
token.exe
TCLASS45.DLL
TOKEN1.DLL
TransLang.dll
most important they are
cxsupervisorres.dll
scs.exe
and files for lic
install supervisor, removes the files that you need for new folder and unistall supervisor (not unistall cx server), et voilá, try
bc500rtl.dll
bwcc.dll
BC450RTL.DLL
BWCC2.DLL
cxsupervisorres.dll
Cc172mov.dll
Czech.lnd
Czech.lng
dbghelp.dll
Danish.lnd
Danish.lng
Data Log Viewer.GID
Data Log Viewer.HLP
Data Log Viewer.ocx
Deutsch.lnd
Deutsch.lng
DONGLE.EXE
DONGLE1.DLL
English.lnd
English.lng
ErrorConvert.exe
Español.lnd
Español.lng
Finnish.lnd
Finnish.lng
French.lnd
French.lng
Greek.kbd
haspdinst.exe
hldrv32.exe
HARDLOCK.SYS
HLINST.EXE
HLVDD.DLL
Italiano.lnd
Italiano.lng
Norwegian.lnd
Norwegian.lng
OWL1A.DLL
Polish.lnd
Polish.lng
Português.lnd
Português.lng
ReadMe.htm
RemoteLogView.exe
Russian.kbd
Russian.lnd
Russian.lng
scs.exe
scsrunps.dll
SCSDEFS.KBD
Slovenija.lnd
Slovenija.lng
Swedish.lnd
Swedish.lng
token.exe
TCLASS45.DLL
TOKEN1.DLL
TransLang.dll
cxsupervisorres.dll
scs.exe
and files for lic
singleperson
Re: [?]: CX-Supervisor 2.0 crack for USB dongle
Dear All,
Do Anybody have crack USB dongle?
Please show me. Because I need crack USB dongle
Thanks and best regards
missfafa
please i need a dongle usb for cx supervisor v3.0
to continue using cx supervisor
dudab
Dear all,
could somebody upload or send me by p.m. USB dongle emulator for CX-Supervisor 2.0?
All the links above are now old and it is not possible to download anything.
Thank you in advance!
Duda
Duda
