does any one know what cable to use to program a Pro-Face
Gp577R-TC11 colour touch HMI
is it programed via the tool port round 8 pin or via RS232 9 pin ?
many thanks
gremlin
The GPW-CB02 It is not a simple cable because it has an internal TTL to RS232 converter. Anyway it is the same of Telemanique programming cable!!!gremlin wrote:i believe the cable i need is a GPW-CB02
this is used by proface GE and XYcom but i canot find a pin diagram anywhere
does any one know what connections are in the lead ?
many thanks
gremlin
Anyway it is the [b]same of Telemanique programming cable[/b]!!!
You can download a block diagram from.
