[?]: step5 convert step7 Function Block
x0914667
Post by x0914667 »
Segment 1 of 1 Lib =19285
Decl
 :OUT I/Q/D/B/T/C
: Q  BI/BY/W/D
: BY
Decl
:O8  I/Q/D/B/T/C
: Q  BI/BY/W/D
: BI
Decl
:O9  I/Q/D/B/T/C
: Q  BI/BY/W/D
: BI
Decl
:O10 I/Q/D/B/T/C
: Q  BI/BY/W/D
: BI
Decl
:STI I/Q/D/B/T/C
: Q  BI/BY/W/D
: BI :C  DB 100
 :L  FY 3
 :L  FY 5
 :!=F  :BEC
:L  FY 5
 :I  1  :T  FY 5
:DO FW 4
 :L  DW 0
:T  FW 254
:L  FY 255
:T  =OUT
:A  F  254.0
 :=  =O8
:A  F  254.1
 :=  =O9
:A  F  254.2
 :=  =O10
:AN =STI
:=  =STI
:JU =?001 " No understand  "
 :L  KH 6500
Where is step5 convert step7 function
It's automatic convert always warning and alarms.
Regard
Alexsan
Post by Alexsan »
Hello.
You found in SIMATIC>Step7>Converting S5 files.
Some of the old S5 FB´s don´t have conversion to S7, you must to re-program; other faults occur when you work with conversions between Integer / Decimal / Real.
Regards.
frankw
Post by frankw »
I think it is difficult to understand the statements Now. Needs the expert of S5.
good Luck
stas
Post by stas »
Hello
Try this manual
S5 to S7 converting manual
Maybe it's help
regards
