Dear friends,
Good afternoon I just want to know if we can service or monitor PLC using internet with simatic cp343-1. Thank you very much.
Warm regards,
Rey
[?]: Service s7 PLC using CP-343 via internet
reymond_craig
nico7773
no problem i do the hotlin for some customer and i connect
on different PLC siemens via internet with some VPN software
The plc has to be on the network connected to internet
but all the companies have a fire wall so the have to open the tcp port 102
to the IP adress of the plc and then it is possible to connect to iy
mohamad
s7-300 plc internet connection with simatic cp343-1?
Hello
I want monitor plc program via internet with cp343-Lean.
pleas help what I need hard/soft ware?
I set IP,subnetmask,router IP for cp 343 in HW configuration in step7ver5.4.
STEP7 can see station in our internal LAN.
How can step7 go online with station on the internet by IP?
Is there other package need?
maybe it must be an addressbar in step7 that can inter IP AND GO web to find the CP?
Is there anyone same connection?
other option is VPN ,
but it must be a way to connect with IP same as the webpages.
mohamad
Hello
