[LINK]: TS_Win v2.40.02 and TS_Win.net v4.10
lonzo
Post by lonzo »
hello,
thanks a lot. :D , booth programms are ok.
af.naderi
Re: [LINK]: TS_Win v2.40.02 and TS_Win.net v4.10
Post by af.naderi »
hi most,
Unfortunately your links does't work.
Can you reuplod it ?
Vagabundo
Re: Request: TS_Win v2.40.02 and TS_Win.net v4.10
Post by Vagabundo »
Hi all,
TSWin.net v4.4 - http://www.sendspace.com/filegroup/2U%2 ... CquqKo8%2F
Passwd: TSWin.net
Good luck :)
zhoujedi
Post by zhoujedi »
missing TSWin.net.part2.rar
vlad2006gr
Post by vlad2006gr »
zhoujedi
Post by zhoujedi »
Thanks. It's WORK.
moviefan
Post by moviefan »
Does anybody have old TS_Win v2.xx?
Carlos
Post by Carlos »
try this 2.4
http://www.datafilehost.com/d/b32be91c
moviefan
Post by moviefan »
Thanks!
Raptor
Post by Raptor »
Please one link sharing?
zaplatin
Post by zaplatin »
Где взять старую версию TSWin.net V2.0 V2.4??
pronto1308
Post by pronto1308 »
TSwIN v4.4
OK It's work.
THX
kastor73
Post by kastor73 »
Hi
Can you please re-upload TS_Win v2.xx (v2.4).
P.S. Does anyone have TS_Dos?
Carlos
Post by Carlos »
t_s 2.40.02
http://www.datafilehost.com/d/f095cb94
zaplatin
Post by zaplatin »
THANKs!!! Куча вирусов правда. Но все равно спасибо!
Парни получилось из одного пульта выгрузить в другой загрузить!
Переходник DB9 DB25 собираем по схеме DCE to DCE (3-3 2-2 8-4 4-6 5-7 6-20 7-5 DB9 -DB25)
http://www.bb-elec.com/Learning-Center/ ... ustra.aspx
(tyou) (tyou) (tyou)
zaplatin
Post by zaplatin »
zaplatin wrote:THANKs!!! Куча вирусов правда. Но все равно спасибо!
Нужна еще специальная версия TSWIN.NET 2 для панелей BT2K с киррилицей. Где можно найти?
na3sanbagollak
Post by na3sanbagollak »
Can someone please re-upload TS_Win v2.xx?
Link is not valid...
saad rashed
Post by saad rashed »
Our dears
We argent need the manuals and software for the
sutron operator panel type 80989.503(BT20)
The soft is TSdos 1.x
Thans
saad rashed
na3sanbagollak wrote:Can someone please re-upload TS_Win v2.xx?
http://fake/suetron-tswinnet- ... ight=tswin
zaplatin
Post by zaplatin »
из BT2K порядок выгрузки нужно соблюдать :
переключить все дип вверх включить питание панели
вернуть дип3 вниз как пишет панель
дождаться пока не добежит строка до конца
после этого подключить панель к ком порту
после этого выгрузится файл S3 который в проект преобразовать у меня не получается .
выгружать пробовал tswin 2.4 и tswin4.4 разницы в полученом файле нет.
avi_j
Post by avi_j »
Может кто-нибудь перезалить TSWin 2.40? Или связаться в пм?
Denrik
Post by Denrik »
Добрый день !Если вы нашли программу TS Win v2.40 или TSDos поделитесь пожалуйста.Спасибо зараннее.С уважением Денис.
