[?]: Step7 v5.4 SP3 - Archive/Retrive problems
Nedjeljko
Post by Nedjeljko »
Hi to all...
I have problem with archiving and retrive in step 7...
...in File menu field "Archive" and "Retrive" is invisible...
...in help file i have found that archiver PKZIP install automaticaly witth step 7 in Step7/S7BIN...yes I have there application PKZIP but isnt active...
...Im try in to the Options/Customize...but there is not any usual options...
...why...ooo why...that hepends to me :roll: :roll: :?: :?: :?: :?:
HotFix1 for STEP 7 V5.4 SP3 = STEP 7 V5.4 Servicepack 3.1
http://support.automation.siemens.com/W ... e/26578452
http://support.automation.siemens.com/W ... _alone.zip ( 114 MB )
What's New (What Fix) in V5.4 SP3.1?
• SIMATIC Manager
- The archiving program PKZip V8.6 CLI supplied as part of STEP 7 V5.4 SP3 will be replaced by PKZip V4.0 from STEP 7 V5.4 SP2 for the operating systems MS Windows 2000, MS Windows XP and MS Windows 2003 Server. PKZip V8.6 CLI will still be used with MS Windows Vista. Note the instructions for use in the STEP 7 Readme file.
- If you already own the archiving program WinZip V11.1 Pro with command line option, you can now integrate this product into all supported operating systems. If you want to use WinZip for archiving purposes, we recommend using WinZip V11.1 Pro in connection with the ZIP file format.
• Configuring and Diagnosing Hardware
- The layout of the HW configurations printout was completed.
- The FW update for F-CPUs was extended by an additional prompt for confirmation.
• LAD/STL/FBD
- The NAND block support with only one input was updated.
• TCI
- Handling TCI connections was improved.
• NCM
- IRT configuration of the CP 1616 was improved.
• PG/PC Interface
- Configuration of the PG/PC interface with Windows 2000, Windows XP and Windows 2003 Server is also possible with user rights. Administrator rights are required for this step with Windows Vista according to this operating system's policies.
• S7-PDIAG
- Display of PDIAG monitoring has been expanded.
Nedjeljko
Post by Nedjeljko »
thanks man :P :P :D :D 8) 8) 8) :wink: :wink: :wink:
