[?] : cable to connect the pc to plc S5
liu2002
Post by liu2002 »
I want to diy a cable to connect the pc to plc S5 (step5),
who can give the diagram,
thanku!!!!!
Umencho
Re: [?] : cable to connect the pc to plc S5
Post by Umencho »
liu2002 wrote:I want to diy a cable to connect the pc to plc S5 (step5),
thanku!!!!!
Hi
Use search option in https://plcforum.uz.ua :lol:
regards
mick_5l
Post by mick_5l »
I made my own using the following:
In the AutoCAD R12 file there is a complete drawing of a RS232 to
20mA Current Loop converter, suitable for data access or programming
functions.
It works on all Simatic S5 CPUs (tested on 100U CPU 100/102/103,
115U CPU941/942/943/944, 135U CPU928, not tested on 150U and 155U)
Since this is a PASSIVE converter (the current source is fetched
from the PLC port), it is not possible to program other devices
such as CP526/CP527 or OP393/OP396/OP5 etc., which require an ACTIVE
(with separate power source) converter.
Istructions:
- Open the file with AutoCAD R12 or higher.
- set the correct scale ratio in your computer to print the drawing
(spacing between the pins of the ICs must be 2.54mm)
- print the drawing onto a plastic transparent sheet (you may
print it on white paper and then photocopy it on plastic sheet)
- use the plastic sheet as master to obtain your printed circuit
by using photo-sensible boards.
S5_COM_TTY_hardware.zip
https://disk.yandex.ru/d/E7g4Fgp_heD7Uw
https://mega.nz/file/iXJVmBYZ#OBN-qw3q3 ... D5DI6JNcvI
https://mega.nz/file/iXJVmBYZ#OBN-qw3q36XusGJ0RDvqKXxdCmWMaWcNxD5DI6JNcvI
mseena
S5 cable Details [150U - CPU924]
Post by mseena »
Hi mick_5l,
Can you please send the link again I am not able to download the file. or is there is any way to upload the 150 U CPU924 program.
Thanks,
klamous
Post by klamous »
Good evening
can any re-upload the schematic of cable programming S5 plc.
indian
Post by indian »
The schematic of S5 adapter I made myself more than 20-ty years ago. Now You probably can't find out cellular phone data cable, so use USB-RS232 TTL cable.
The schematic is quite simple to understand how does it works.
http://gofile.me/400mr/MofAcjIgE
