[?]: Protool and incompatible new panel MP277 10"
Nedjeljko
Post by Nedjeljko »
Hi.
I make new project, and want to use old project like basis to new one.
That older project maded in protool with MP270B 10", and hardware for new project is MP277 10".
In that old project Im try to change device type, but in software Protool V6.0 SP3 I cant find panel MP277 10" in data base :cry: :cry:
...Does anyone know for some newer version of Protool which has a panel MP277 10".
...or maybe some updates of protool in existing version Protool V6.0 SP3
...Please help me, or I will loose much time to do new project in WinCC flex 2005
Nedjeljko[/b]
Contact:
You can migrate (convert) old ProTool projects in WinCC Flexible.
I have converted old MP370 projects to new WinCC Flexible projects.
Nedjeljko
Post by Nedjeljko »
..yes now Im trying to migrate protool project into the wincc...
...Im opened WinCC and choose open protool project.
...I opened .pdb file click on next buton and then on screen shown error window from WinCC...
...see this screen shots
http://docs.google.com/Doc?docid=dg4923 ... ghgz&hl=en
...What Im doing wrong!?...or I have bad version of softwares..
I have WinCC flex 2005 SP1 HF6 and Protool V6.0 SP3
... :cry: :cry:
Any Idea!?
Contact:
I have converted your project without problems by Flex 2005 SP1 HF7 Advanced
See mail.
Nedjeljko
Post by Nedjeljko »
...yes thanks for trying...you have HF7 and my last HF is HF6...and that is not compatibile...
..I have succsess on my second PC whic is new station, I have install new WinCC and Step7 and migration works ok...
...but now how to make integration Migrated WinCC file into the original Step7 project?!?
...In WinCC Im try to go in File->Integrate in Step7...and blue indicator shown blue line till midle of indicator..and thats it...I again look into project of Step7...and nothing hapend...Im traying with closed Step7 and whit opened project in Step7... :? :? :lol:
....Thanks
Contact:
Nedjeljko wrote:...yes thanks for trying...you have HF7 and my last HF is HF6...and that is not compatibile...
See link http://support.automation.siemens.com/W ... n/24758642
Nedjeljko
Post by Nedjeljko »
..Can you try integriert new WinCC file into the Step7...please...
...I have succses with recognize a project from WinCC to Step7, but I want to add WinCCRT into the rack...no succses...
...This Im doing for first itme and maybe Im something doit wrong... :? :? :? :| :?:
Contact:
Start Step7
Start Flex
Menu Projects>Integrate in Step7
after integration
select PLC in Connections window
Nedjeljko
Post by Nedjeljko »
... man thanks for everything...
...problem was in Step7... I fixed it in control panel trough Ad remove software...choose repair Step7 and now everything work fine...
...WinCC 2007 is faster than 2005...now my PG work propertly 8) 8) 8) :D :D :D :D :wink: :wink: :wink: :wink: :wink:
...I like this forum... :wink: :wink: :wink: :wink:
