Hi All
we use some Proximity sensor in pasta Dryer But After 1 or 2 Month the sensors fail to function properly and we shuld change them.
the Dryer is On all the Times and in Normal mode sensors sense every 8 Second
Dryer Temperature is 80 ^C and Humidity is 70% .
water Temperator for Heating dryer is 120 ^C and Sensor shuld work in this Temperature.
which Company Have a Good Sensor for this Application ?
thanks a lot
[?]: Proximity Sensor for High Temperature and Humidity
shabany
Maxime
Prox
Hi Shabany,
what brand is it now?
Did you allready talked to the company where you're using your actual proxes?
There are a lot of brands, look up the internet.
Sick, Pepperl & Fuchs and IFM and many more, you have to contact them and explain your problem. Or search yourself for a better type in specs, maybe ask some purchaser to come and give some explonation about products.
Regards
Maxime
Regards
Maxime
