[LINK]: Caddy++ v3.82 English
mertosgalim
I need to Caddy++ v3.82 English please!!
A= 12345678 this is the serial number for license
B= here, you put the number code of the license (to the left side of status/day, that is yellow color)
generate,
yellow color becomes green.....
most
Crack is not working
Dear friends,
I have install Caddy , but when I try to introduce the key generated is a problem:
The soft (Caddy) it say no 30 or 29 or ..... days left. The background is red not yellow or green like in yours description .
The keygen looks ok but Caddy does not accept the key.
Can you give more suggestions..?
dekor.
dekor.
Is still not working
Dear friends,
I have try to install the program on diferent computer.
The diference is : now is counting the trial days left.
About the keygen any sugestion ?
From your experience, what can be wrong?
dekor
dekor
caddy++3.82
Can anyone confirm that the keygen is working with the english version
keygen is not good
Dear friends,
I think the key gen is not good. I will explain:
By mistake I have installed the Russian version in one computer.
When I use the keygen for the Russian version and I search for the caemanager, automatically the personal number which appear in the keygen is the same with the number from licensing wizard.
On different computer I try to install the english version.
With the keygen for english version this number is diferent, and the key is not good.
Even when I put manually the number in keygen like in wizard is still not good results.
All the best things for you.
dekor
dekor
Re: keygen is not good
for me is english version and works well.dekor wrote:Dear friends,
dekor
if it does not function for you, sorry, you have to look another version.
most
