[?]: conection between protool & plcsim 5.3 sp1
joopiter
Post by joopiter »
Hello friends
i want to connect a protool v6 sp3 to a plcsim 5.3 sp1 with a mpi network in step 7,but i could not do that.
is it posible to make a connection between them?
and its possible what should i do?
joopiter
Post by joopiter »
i did what u said but i could not connect them to gether,
my plcsim is ver 5.3,
this message is shown
"the tag can not be written to the plc" :cry:
you need set mpi-adress of plcsim!
joopiter
Post by joopiter »
dear sania
i have done all i should do in step7 netpro,should i do something in plcsim program?
sorry i have one othere quesion ,i did not make any area pointer in protool ,only i made my tages with the plc addreses.is it important for communication between them at all?
you check link of CoMod?
1)run plcsim
2)you need download your programm into plcsim
3)you need set MPI-adress of plcsim analogicaly of your CPU
4)start runtime protool
joopiter
Post by joopiter »
yes i saw the link that CoMod said and i did it
but i dont know what shoul i do in step 3 as you said,sania?
how should i set my plcsim mpi addres?i did it in step7 netpro.and download the program to plc sim ,is there any setting need in plcsim program?
and here i saw something in protool v6 manual,there was written that protool v6+sp3 can work with plcsim ver5&5.2 ,my plc sim is ver 5.3+sp1 ,is it possible that protool ver6+sp3 do not support the plc sim ver5.3
joopiter
Post by joopiter »
dear sania
thanks a lot
