[?]: How to backup (upload) the HMI file from OP17?
I want to upload op17 to protool for making a copy. How can i do?
liu2002 wrote:i use the fuction upload, but i don't know how to set, just like which slot to link. use the cable which i use to dowload the file to op?
Hi again
Read manual about OP17. https://support.automation.siemens.com/ ... nload=true
And here is the list of panels and what kind of function you can do with defferent type software. https://a248.e.akamai.net/cache.automat ... r_e_C2.pdf
And now with protool and this type panel you can only make download with protool. not upload. For upload you'll use PROSAVE. But I repeat you just make backup not for make any changes.
regards
