[?+]: problem in Protool 6 for starting a new PC project
joopiter
Post by joopiter »
hello friends
i have a problem with protool 6+sp3
i want to start a new project for a standard pc,when i open a new project i can see all kinds of OPs TPs,MPs but i can not see PC,what should i do? :?:
You use Protool is not Professional Edition mode.
Use search.
After installation Start>Run> enter REGEDIT and replace Registry key
[HKEY_LOCAL_MACHINE\SOFTWARE\Siemens\PROTOOL\6.0]
Protool Pro
P06000000F:02354=618>>;=;:T>>71;:4>K
Before and After Regedit correction
votuandktd
Post by votuandktd »
You would use WinCC Flexible
Good luck,
Dreamer76
Post by Dreamer76 »
votuandktd wrote:You would use WinCC Flexible
Good luck,
you cant project older panels with win cc flex. so sometimes you must use protool. maybe protool is a bit difficult to use.win cc flex is easier.
ciao
Dreamer76
votuandktd
ciao
Dreamer76
You right! But the question is using Protool in the standard PC.
Best regards,
joopiter
Post by joopiter »
Dear Dfcz thanks a lot for your help,i did what you said and my problem solved,really thanks a lot
Dreamer76
Post by Dreamer76 »
votuandktd wrote:You right! But the question is using Protool in the standard PC.
Best regards,
i think yes :)
ciao
Dreamer76
