[?] simple piece of code not working (STL).
stargazer
Post by stargazer »
a simple check if the value DB50.Man_Speed_1 is in range (0-100).
doesn't actually work (in PLCSim for now).
// Check if entered value is above zero
      L     DB50.Man_Speed_1    // should be above 0
      L     0.000000e+000
      >=R
      JC    CH1
      L     0.000000e+000
      T     DB50.Man_Speed_1    // is set to 0
CH1:  CLR
// Check if entered value is not more than 100
      L     DB50.Man_Speed_1    // should be less than 100 or equal
      L     1.000000e+002
      <=R
      JC    CH2
      L     1.000000e+002
      T     DB50.Man_Speed_1    // is set to 100
CH2:  CLR
where did I go wrong?
graf_STEP7
Post by graf_STEP7 »
Hi
You Code are work.
if DBW --> DBD dw
Try this modify Code:
l 55.0
t md50
      L     md50   // should be above 0
      L     0.000000e+000
      >=R
      JC    CH1
      L     0.000000e+000
      T     md50                     // is set to 0
CH1:  CLR
      L     md50                     // should be less than 100 or equal
      L     1.000000e+002
      <=R
      JC    CH2
      L     1.000000e+002
      T     md50                        // is set to 100
CH2:  CLR
When this Code are work, test the Variable "DB50.Man_Speed_1".
Is it Posible, the result is Override your Variable fron an another Prozess.
Sorry for my English :oops:
see in russian http://plc.net.ru/viewtopic.php?p=15017#15017
P.S. in future don`t duble post :!:
