[?]: Driver for S5 CP1430 TCP
magoto_1
Post by magoto_1 »
SOMEBODY HAVE SOFTWARE FOR CONFIG CP1430TCP?
magoto_1
Re: THANK A LOT
Post by magoto_1 »
I WILL TRY AGAIN
THANK YOU.
DO YOU HAVE MANAUL OR DOCUMENT OF HOW TO CONFIG CP130TCP?
I TRY TO CONNECT WITH CP1430.ZIP BUT CANNOT
THANKS
Umencho
Re: THANK A LOT
Post by Umencho »
magoto_1 wrote:DO YOU HAVE MANAUL OR DOCUMENT OF HOW TO CONFIG CP130TCP?
Hi
About software:
Try this: https://support.automation.siemens.com/ ... reecontent\
If you have some questions let me know... :lol:
You don't need manual about CP1430. But if you try search in google - you'll find.
About hardware: You need cable - cross or right. Depends fro your type of connection. (direct or with switch). The cable siemens's number is 6XV1850-2LH20 (2m long). Or more detail find here : https://support.automation.siemens.com/ ... ype=130000
regards
umencho
magoto_1
Re: [?]: Need the Driver for S5 CP1430 TCP
Post by magoto_1 »
magoto_1 wrote:SOMEBODY HAVE SOFTWARE FOR CONFIG CP1430TCP?
configuration tool of CP1430, "SINEC NCM COM 1430 TCP".
what do you want to say?????
magoto_1
Post by magoto_1 »
I need software configuration tool of CP1430 TCP/IP.Do you have it?
About CP1430 of your file can't config this card.....
best regards.
did you know use it?
unpack into folder,run S5,go to menu CHANGE-OTHERS,explorer to you folder,see SINEC NCM COMS,press START
magoto_1
Post by magoto_1 »
sania wrote:did you know use it?
I already do it but not work it is driver for CP 1430 TF , Can't change to TCP
Thank a lot
esdras_jrsolutions
Re: [?]: Driver for S5 CP1430 TCP
Post by esdras_jrsolutions »
THERE ARE 2 MODULES=>CP1430 TF (ISO TRANSPORTATION) AND CP1430 TCP (TCP / IP TRANSPORT)
FOR CP1430 TF = SOFTWARE=>COM1430 TF
FOR CP1430 TCP = SOFTWARE=>COM1430 TCP
SOMEONE HAS TO DOWNLOAD THE SOFTWARE "COM1430 TCP"?
OR MY E-MAIL TO POST THIS SOFTWARE: ESDRAS@JRSOLUTIONS.COM.BR
THANKS REGARDS!
garf
Post by garf »
I am in desprate need of the software for
COM1430 TCP
Many thanks
sharmagopals
Driver for S5 CP1430 TF
Post by sharmagopals »
Is someone have COM Pack for S5 CP 1430TF
Thanks,
Gopal
coctrubenm
Post by coctrubenm »
Hello, please help me download Sinec NCM V5, it is to configure a 1430 card in an S5-135U, I already have Step 5, but I am missing this plugin, PLEASEEEEEE!
