[?]: PC runtime project wincc flexible or protool as service
Does anybody try startup on PC runtime project wincc flexible or protool as service?
yes you can do it.
you need instsrv.exe and srvany.exe from the ms resource-kit
for example look here http://www.iopus.com/guides/srvany.htm
download the exe-files look here http://www.electrasoft.com/srvany/srvany.htm
I try do it with these programs. When I startup new service appear fault that this service dont't startup on local PC.
I tried statup wincc flexible runtime project as service (W2000) with use srvany.
Appear fault:
Appear fault:
fault wrote:Could not start ... service on Local Computer.
The service did not return an error.
This could an internal Windows error or an internal service error
