HI
Personal of the forum I am the search of the MR configurator Mitsubishi
thank
flopez
[LINK]: Mitsubishi MR CONFIGURATOR
flopez
jamrobe
MR-Configurator Serial Number -ID
Hi all.
From the other links I have downloaded/ installed MR Configurator 81E, 161E, 221EVB1
81E, 161E went OK, but I never worked with them and for some reason on File tab Open, Save and Print are greyed out.
I would like to play with the parameters to see how they look like.
On 221E they are asking for an ID number.
Does anyone has it for sharing?
Kind Regards
Jamrobe
Kind Regards
Jamrobe
most
Re: MR-Configurator Serial Number -ID
see the file in the http://plc.net.ru/viewtopic.php?t=8252jamrobe wrote:Hi all.
Jamrobe
this 221E not need serial (for MR-J3-A e para MR-J3-B )
if you want install 221EVB1 (for MR-J3-T, MR-J3-B Linear e MR-J3-Fully Close) changes the file "setup.inx" of Setup221E for Setup221EVB1 and install.
221EVB1 functions as update of the 221E
or test this file [dead] :/138561943/s ... x.rar.html
most
most
