[?]: optimal Simatic package on notebook ?
Questions about Siemens & Analog Siemens hardware.
Software & hardware exchanger
Dreamer76
Post by Dreamer76 »
huhu
i want to install step 7 on my notebook to programm s7 200 / 300 / 400 cpu
now i have install
step 7 5.4 SR4
microwin 4 SP5
protool Pro 6 SP3
wincc flex 2007
system diagnostic 4
what kind of simatic is important? i dont want to install all
please help me
thanks
ciao
Dreamer76
company66
Post by company66 »
for me you have installed all what a tecnician need for programing
what you have to do now is begining to use it.
best regards.
Dreamer76
Post by Dreamer76 »
ok thanks for your answer. i'm program only a year with s7. i come from a other automation system. it was a bit difficult to change.what kind of simatic sw have you installed?
best regards ciao
Dreamer76
I also use DriveES with Starter for inverter
Dreamer76
Post by Dreamer76 »
comod what is better drive es or simotionscout?
or is this nearly the same?
ciao
Dreamer76
Scout include DriveES
Dreamer76
Post by Dreamer76 »
ah ok
sorry for this quest
Umencho
Post by Umencho »
Hi
Maybe Simatic NET :roll: but it depends from your project :wink:
regards
marcs7
Post by marcs7 »
don't forget PLC SIM ..
Umencho wrote:Hi
regards
No simatic net only for PC based automation, simatic net made error on wincc flexible and network connection..
take your new windows installation
connect you pc on a network
install step7 flexible..
disconnect your network
install simatic net ... and start wincc flexible :shock: ( sql server not found and etc....)
and simatic net doesn't de-install properly .. :evil:
Umencho
Post by Umencho »
marcs7 wrote:don't forget PLC SIM ..
Hi
about simatic net and wincc flex this is true :oops: . I had bad expirience with this :cry:
And maybe the PLC SIM have been already installed. Dreamer76 wrote step 7 SR4. :wink:
Dreamer76
Post by Dreamer76 »
thanks for your help :)
what kind of simulation do you use?
what is the best way to watch the Input/Output/Merker/Timer/Counter ... (when they high or low) over a longer time to find difficult errors?
ciao
Dreamer76
i wish everyone here in this board merry christmas and a good slide in the new year.
great board :)
Alexsan
Post by Alexsan »
Hello.
If you are using Siemens PLC, PLCSIM is useful for simulation.
To verify the state for IOs, you need to use Step7 software, also would be better if you have the specific application program source code (documented).
Regards
