I downloaded Simatic_EKB_Install_2007_11_27.zip but at runtime it throws lots of errors.
It starts with access violation error and subsequently lots of "index out of bounds" errors.
Saome help?
[?]: Errors on Simatic_EKB_Install
maufus
See about this error http://plc.net.ru/viewtopic.php?t=218&start=30
I also have a laptop with only one harddrive no floppydrive,I had the same problem as the one described on your web page.
Access violation at address 004BDF4E in module 'Sim_EKB_Install_2007_11_27.exe'. Read of address 00000000
I have a laptop with only one harddrive no floppydrive.
When I start the program it makes the "access violation" error,
when I then add an usb drive the program can start.
It seems like the program wants to select disk number 2 in the dropdown box, it would normaly be the "c" drive but only if you have a floppy drive installed.
I hope this helps
buty I divide a disk into 2 partitions C:\ and D:\.
Therefore I do not see similar errors
---- Fixed ------in Russian wrote:Эта проблема проявляется на нотебуках без гибкого дисковода и c жёстким диском только с одним разделом.
Так как у меня тоже есть нотебук без дисковода, но жёсткий диск всегда поделён на несколько разделов, то я этой ошибки не замечал.
Устраню.
Index Out error for notebook with only one disk C: (without floppy)
add key for Sinema E
add Big Yellow USB Stick image (with ~1400 short, long SIFL* and SISL* keys - for this is very slow in ALM)
[dead] :/75012058/Si ... 12_07a.zip
7105 KB
or for russian inet users (Доступен до: 2008-01-07 11:30:09 )
http://ifolder.ru/4469225
