[?]: comtext to protool and step5 to protool?
ausnis
Post by ausnis »
Can I convert a program comtext to protool?
And I can communicate step 5 with protool?
Dreamer76
Re: [?]: comtext to protool and step5 to protool?
Post by Dreamer76 »
ausnis wrote:Can I convert a program comtext to protool?
huhu
first quest :no
second quest: when your hw support it yes
ciao
Dreamer76
brave_eagle
Post by brave_eagle »
first, you cannot convert the comtext to protool directly, you should use one small tool named "converter" to export the program from comtext, then insert the exported intems to protool
