I'm pretty new to all this SIEMENS controller stuff when it comes to text panels.
I have TP170B MONO and S7-200 CPU (222.).
I have all the neccesary software for them (ProTool 6 and S7 MicroWin 3.2).
I used null-modem cable to connect the panel to PC and I succeeded.
How can I connect the panel and the CPU?
What cable and what settings do I have to use?
P.S. You can answer in russian too- I understand it but I can't write pretty good.
[?]: Connecting S7-200 CPU to TP170B with ProTool 6
fest
See FAQ with example
How do you synchronize the system clock between a Windows-based panel and an S7-200 CPU with ProTool?
http://support.automation.siemens.com/W ... n/18644602
and S7-200 Communication possibilities
http://support.automation.siemens.com/WW/view/en/41561
