[LINK]: License for Kepware LinkMaster
liwei
Post by liwei »
I am looking license or keygen for Kepware LinkMaster
Would you please help me?
Best regards.
frankw
Post by frankw »
You can use the Kepware KeyGen to generate the SN and PW.
Using WinHex to change 2bytes of Keygen file, what is the file address ?
so sorry, I will Update it quickly.
frankw
Post by frankw »
LinkMaster KEYGEN :
2 years ago,I made it by changing Kepware KEYGEN V4.160.316U at file addr. 3418, replace 5500000084464000 to C201000084464000
then select AB Bulletin 900 Device Driver
Good luck
mech962784
Post by mech962784 »
Dear Frankw
i was not able to find neither the offset address you have mentioned nor the 5500000084464000 ?
i have used both the hiew and winhex?
can you please clarify it little bit?
Best Regards
Schtiel
Post by Schtiel »
mech962784 wrote:i was not able to find neither the offset address you have mentioned nor the 5500000084464000 ?
That's because the file is packed. I've made a necessary replacement for you.
Enjoy!
[dead] :/85284478/LinkMaster.zip
mech962784
Dear Schtiel
Thank you very much for your kindness,
But i am facing one problem with your keygen.
the license number is working fine
but for generating the unlock number based on the computer ID,the unlock code is not working and still it is giving that i have a temporary license for 10 days!! (i am using linkmaster V2.37.124.0-U)
any help or guidance please either from you or mr frankw.
we are suffering a lot with this software,but i know that you guys can do it ;)
Best Regards
liuxianfu
Post by liuxianfu »
it is not LinkMaster Key.
Schtiel
Post by Schtiel »
It was made from other Kepware keygen. Select AB Bulletin 900 Device Driver for LinkMaster Serial Numbar generating.
youhm
Post by youhm »
I would also like Mech962784 and can not get the correct password
frankw
Post by frankw »
I found out the reason,
the LinkMaster P.W. calculation is still unchanged, so the version of Kepware KEYGEN you used should be older than V4.160.316U, I can not find it now.
zenchek
Post by zenchek »
Hi frankw
This is original keygen V4.160.316U
[dead] :/86242819/SO ... U.rar.html
Please, patch and share it.
Regards zenchek
Sparrow
Post by Sparrow »
Dear Schtiel
Thank you for your work,
But i am facing the same problem with the Keygen too.
i am using linkmaster V1.21.76) :shock:
best regards
vlad2006gr
linkmaster
Post by vlad2006gr »
http://www.kepware.com/Products/Downloa ... Master.exe
www.kepware.com/Products/downloads/KEPServerEx.exe
For LinkMaster:
Download [dead] :/96227679/KEYLIB32.rar.html
1. Install LinkMaster.
2. Enter S/N 7-20038-62386627188-3650
3. Close LinkMaster.
4. Replace KEYLIB32.dll
5. Run LinkMaster.
6. Open Help, Unlock and enter any namber (example 1234321)
7. Done
Good luck!
scaramanga
Post by scaramanga »
Does anyone have a link or info for cracking kepware ClientAce?
cheers
votuandktd
Post by votuandktd »
Please post again file KEYLIB32.dll. I can't download it.
Many thanks.
pai-pro
Re: [LINK]: License for Kepware LinkMaster
Post by pai-pro »
LinkMaster KEYGEN :
Many thanks.
Download [dead] :/96227679/KEYLIB32.rar.html not working
budisanuri
Post by budisanuri »
its work for.. thanks vlad2006gr (thnx)
lxiaob
Post by lxiaob »
Is there anybody can post KEYLIB32.dll again?
The link [dead] :/96227679/KEYLIB32.rar.html is broken.
Thanks in advance.
chenchen2314
Post by chenchen2314 »
My project need communication with 2 OPC SERVER.so I use the linkmaster.
I can't generate the right password,
so who can post a useful KEYLIB32.DLL.
thanks very much. (wow) (wow)
ciwa
Post by ciwa »
re-upload the file please...
vlad2006gr
re link keylib32
http://dfiles.ru/files/uxqlby83y
Good luck!
ciwa
Post by ciwa »
thank you Mr. Vlad...
brave07
Post by brave07 »
vlad2006gr wrote:re link keylib32
Good luck!
Mr. Vlad. Please re-upload file
vlad2006gr
Link is good. See how to download-
http://www.4shared.com/office/a2-1td0Nb ... lesru.html
Good luck!
harek10
Post by harek10 »
Hello. Help please. Could you reload old version linkmaster kepware? (sos) (sos) (sos)
wiser87
Post by wiser87 »
Update the link to the program LinkMaster
Hello_there
Post by Hello_there »
I work at Kepware. First off, thank you for using our tools. I am glad that you like them and I hope that you have a great experience. In the future, though, from one person to another I hope that you consider purchasing our software. We offer multi-week temp licenses! We all work really hard to build these tools, and our company means a lot to us and to our small home city. Thanks for reading!
