[LINK]: Downtime Monitor (WinCC DTM)
Supreame
Post by Supreame »
Hy
Does anybody know how can the speed of machine be set dynamic in connection with a tag (float type) from WinCC?
I have to offer the possibility to change the speed of a machine [e.g. nr. of pieces/minute] from the client interface (.pdl file in WinCC).
Any advice regarding the Downtime Monitor is wellcomed! (including the kit :) )
http://support.automation.siemens.com/W ... n/26664769
Thanks!
dante
Post by dante »
1. how is the speed set at this moment? (when is not set from WinCC)?
2. is it automatically adjusted?
3. do you have a potentiometer for speed?
Supreame
How the speed is set now
Post by Supreame »
1. Now the speed is set from Downtime Monitor > Equipment > Attributes Management > Design Speed > Value: "15"; Unit of Measure: "Items / Minutes"; (as an example).
I can't change that value ("15") from a WinCC Tag (once the speed is set in Downtime Monitor it can't be modified unless a new version of Downtime Monitor project is created)
2. The speed is not automatically adjusted: the client must have the possibility to change this value regarding the production type of items of the machine (e.g. today: 15 items / minutes, tomorrow 60 items / minutes)
3. No, the speed should be set from a WinCC interface (PC) (operator input)
(I assume that this can only be done with a tag, but the problem is that this tag can't be set as "Value" in Downtime Monitor - point 1 of the answer).
dante
Post by dante »
unfortunately I've no ideea about Downtime monitor, but I assume that value goes to a PLC and that is the machine speed setpoint; that case I would define a new "place" into the PLC for the speed and set it from WinCC (pdl).
Supreame
Ok
Post by Supreame »
But the problem remains opened: read WinCC tag to set the speed in Downtime Monitor.
Link
Forum Community
Forum Community
Post by Link »
DowntimeMonitor for WinCC7.0 sp1
3 * 100.000.000 + 86.592.374 bytes
https://rapidshare.com/files/1359136496 ... .part1.rar
https://rapidshare.com/files/1391880240 ... .part2.rar
https://rapidshare.com/files/842875300/ ... .part3.rar
https://rapidshare.com/files/3111469634 ... .part4.rar
NRG is Nero CD/DVD Image File
Open by Nero Burning ROM or UltraISO - see viewtopic.php?f=2&t=6036
Update 4 for SIMATIC WinCC/DowntimeMonitor V 7.0 SP1
https://support.automation.siemens.com/ ... 0_UD_4.zip
114 mb
about
http://support.automation.siemens.com/W ... n/28881800
key SIFLPIDT0E0700.EKB WinCC DowntimeMonitor (200)
frankw
Re: [LINK]: Downtime Monitor (WinCC DTM)
Post by frankw »
Please share the DOWNTIME MONITOR in EMULE or narod.ru, i can not link Rapidshre.
