[?]: convert this programme from step5 to step7
tekman2007
Post by tekman2007 »
hi all
im a beginner in plc programming
i have a machine that uses siemens plc,the programme is written using step5 programme
i want to reprogramme the plc using step7 software,i have downloaded step7 programme from the forum links,also i read how to convert step5 files to step7 files,but when i installed the step7 programme i cannot find the coversion tools as inicated on siemens guide
i upload the programme in step5 language so plz any expert can convert it to me to step7 and upload here
thankss
link1
[dead] :/68702215/uniflow.rar.html
another link
http://www.sendspace.com/file/p5guw2
Umencho
Post by Umencho »
Hi
If you read carefully the manual about S5-S7 convertion, you'll see that something from S5 is imposible to convert in S7. And the tool for convertion you can find in START-SIMATIC-STEP7-S5_S7 CON.... :wink:
And "translation" of programm must doing from men, who know how mashine work. :roll:
From Simatic menu
regards
bunglehead
Post by bunglehead »
What PLC are you working with? I never heard about simatic CPUs which both support S5 and S7..too different environments (may be you plan to replace whole system I don't know). I don't know about S5 but S7 uploading doesn't support symbolic insertion in DBs (symbol table can be used of course by simple copying)..without symbols only very simple program can be easy read by human being.
Mike H
Post by Mike H »
Can you give the exact number reference (6es7 xxx-xxxxx-xxxx) of each part of your S7 material: in S7 project, there's not only the program, the exact type of your material is also include, even the power supply.
Then, to translate your project in a valide S7 project, we must have the right references.
dante
Post by dante »
It does nor exist PLC accepting S5 AND S7 programs.
If the PLC color is black you MUST use S7; if its light yellow/grey you MUST use S5.
If you want to change the S5 with S7 you can try automatic converting of S5 prog to S7.
Althrough, I am warmly reccomanding you to do it manually.
Hans
translation
Post by Hans »
I have translate it. [dead] :/73865171/Uniflow.zip.html
You should verify S7 and S5 version.
company66
Post by company66 »
Thanks Mr HANS for helping a menber of our community
thanks a lot.
best regards.
