[KEY]: Key for Schneider OFS (OPC factory Server V3.31 L)
другие контроллеры
zenchek
Post by zenchek »
Who would like to share key for Schneider Electric OFS ( OPC Factory Server V3.31 Large. )?
Thanks in advance.
zenchek
KSerg
Post by KSerg »
You can try serial for OFS V3.3:
serial: 21063301323
part number: TLXCDSUOFS33
the correct serial is:
part number: TLXCDLUOFS33
serial: 21063301323
zenchek
Post by zenchek »
KSerg wrote:You can try serial for OFS V3.3:
serial: 21063301323
Very thanks KSerg, but other number named AUTHORIZATION CODE is necessary too.
Regards zenchek
c0den
Post by c0den »
After 5 minutes of fine analisys ... try this:
Use UnityKeygen_noRelease
Type the EntryNo and the ComputerID as the registration Tool sugests...
The field AuxNo, type the number 532 (and not the 700).
Pick the number in the middle...
Tada!
Ps. Tested it here, and work´d.
c0den.
zenchek
Post by zenchek »
Many thanks cOden,
the medicine have instant positive effect.
Best regards.
zenchek
Schtiel
Post by Schtiel »
cOden, thank you very much!
Can you help us with Schneider's SCADA Monitor Pro? Is it possible to use your great keygen for it?
c0den
Post by c0den »
Hum... i´ve looked around here... but i dont have this app here....
Share the link and I see what I can do for ... ;)
c0den
most
Post by most »
hello c0den
Thanks for your keygen, it is useful...
can you adapt this keygen for Proworx32 by Sch of this link:
http://www.telemecanique.com/85256DCC00 ... enDocument
many thanks
most
c0den
Post by c0den »
http://download.telemecanique.com/Repos ... group10~EN
look at and see that ther´s a 2.0 version, and also it´s a version that i do have it here... well... i´m going to see what I can do (for the 2.0 version) ...
c0den.
niila
Post by niila »
Schtiel wrote:cOden, thank you very much!
hi friends..
you can try below link , it will probably successful :D
115110NA
B7IN GD2H Q45R PDDN VU3I ENSD TAEF BAK8 3D
EXFT VD6S 3TIX 4GQW H3DS J32C NC
most
Post by most »
c0den wrote:http://download.telemecanique.com/Repos ... group10~EN
c0den.
i will download the V2.0, i didn´t know your link
many thanks for your work
most
c0den
Post by c0den »
Go to http://download.telemecanique.com and you´ll find it.
Well, i´m now analysing it, it appears to be the same thing as the Unity and to the OFS.
Wait for results.
------- snip ------------
All right... I got it again...
I´m going to post a Modified version of CrackUnity, it worked again to the ProWORX32 (v2.00), but I had to change a few things to CrackUnity Code.
Just wait a bit.
Here´s the link, it has support for OFS, UnityPro, and also for the ProWORX32. Try it, i´ll delete the file at end of the day for security reasons.
-- Link Deleted !! --
[dead] :/69000103/Ke ... E.rar.html
c0den
c0den
Post by c0den »
Ok fellows
I´ve given to you one nice keygenerator for Schneider´s best appz, now it´s time to have some feedback ... I need the keygen for GENESIS32!!!
c0den
most
Post by most »
ok. the program is autorized.
tomorrow i will test online with PLC to verify if i have more than 25 networks
(I go to try to find something for genesis32)
many thanks
most
Schtiel
Post by Schtiel »
niila wrote: hi friends..
115110NA
But this are only serials... Activation code depends from PC configuration. A keygen is necessary... Please help...
c0den wrote: Share the link and I see what I can do for ...
Thanks! I'll try to upload it as soon as possible.
c0den
Post by c0den »
About the 25 Networks... Hum, try the second key that the program returns, the Screen has disapeard after inserted the 2nd key. (it was appearing with the 1st).
c0den
most
Post by most »
c0den wrote:About the 25 Networks... Hum, try the second key that the program returns, the Screen has disapeard after inserted the 2nd key. (it was appearing with the 1st).
c0den
yes already it had seen. with the first number it is autorized but the mesage does not disappear, with de second number,Yes, the mesage go out. I go to try online tomorrow and i say some thing
regards
most
it works well, i see more than 25 nets
one more time, Thanks
Schtiel
Post by Schtiel »
c0den
I can't upload Monitor Pro right now, it is too big... Here is the License Utility from it:
http://www.sendspace.com/file/ksyj1p
Please look for it. Is it have a similar protection?
c0den
Post by c0den »
Here´s the problem:
The File LicenceWizard.exe needs additional dll´s (and the security check resides into some of them) ... so it´s impossible for me to take a look the security, try to find a good link of Monitor Pro and I´ll see what I can do.
c0den
Schtiel
Post by Schtiel »
c0den,
here is the setup of the license utility. It contains all the necessary DLLs. Please try:
http://www.sendspace.com/file/60t6ph
most
Post by most »
olá c0den
something is badly with the program proworx32
i can not edit in offline and i can not open samples !!!!
without authorization everything works but only 25 nets, with autorization i can edit only online with PLC !!?
can you solve this problem ?
or in alternative could you activate this program proworx_nxt that i upload (this program have a fix file but it doesn´t work)?
you are specialist in schnei_der, can you help me again and losing your time ?
[dead] :/69747736/p. ... 1.rar.html
regards and thanks
most
c0den
Post by c0den »
Sorry for delaying any answer... Too much busy right now.
I think that this weekend I can take a look on this problem.
c0den.
serg_mds
Post by serg_mds »
hello c0den
Could you repeat upload the keygen for OFS 3.31L on rapidshare
In advance thanks.
vlad2006gr
Post by vlad2006gr »
I have trial OFS v3.3. It is necessary setup.inx.
Please upload setup.inx OFS v3.3
Schtiel
Post by Schtiel »
I have OFS v3.2 only. Here is a setup.inx file for it:
[dead] :/75802444/setup.inx.rar
care4u
Mirror and reupload of KeygenUnity
Post by care4u »
Please can someone upload again KeygenUnity_ProWORX_OFS_noRELEASE.rar. Preferably in Non-Rapidshare file sharing. Thanks alot in advance.
frankw
Post by frankw »
the link is not working! I need the keygen for ProWorx32 v2.0 or the key code:
Code Entry Number:319622086
Computer ID:894272
Authorization Code:???????
most
Post by most »
(6170693)
6451287
the second nº is better
with out autorization you can edit in offline, with the autorization you can edit only online (?)
most
frankw
Post by frankw »
The codes can not be used.
waiting the keygen.
dev
OFS copy to share
Post by dev »
CODEN PLEASE HELP ME I NEED IT URGENTLY WITH KEY
SMart
Hi
Post by SMart »
I have OFS 3.0. ? so i need some keygen for that. some day ago i've downloaded KeygenVijeo - if this tool can halp me? please tell me
AUXNo ffor OFS or othe keygen/ Thanks
satapia
ofs v3.3
Post by satapia »
Porfavor gente , si es q alguien pudiera brindarme un link de descarga del OFS v3.3 o superior , por q tengo el 2.2 , y no logro conectar mi twido
gracias
zenchek
Re: ofs v3.3
Post by zenchek »
satapia wrote:Porfavor gente , si es q alguien pudiera brindarme un link de descarga del OFS v3.3 o superior , por q tengo el 2.2 , y no logro conectar mi twido
gracias
In alternative,you can use the KepserverEX.
http://www.kepware.com/KEP_KB/default.a ... 1&catId=57
Link_Emule:ed2k://|file|Kepware.KEPServerEX.v4.264.401.Incl.Keygen-SSG.rar|37519673|35B2299AA7D5ACC5B976A7FEA5CD247E|/
Regards - Saludos - zenchek
satapia
very good
Post by satapia »
thank you my friend , i installed the one from the official webapage , because i skip using emule , would i need i password , key license or something like that ?
if yes , could you make a rapidshare link for the emule link you posted , thank you very much men
zenchek
Re: very good
Post by zenchek »
satapia wrote:thank you my friend , i installed the one from the official webapage , because i skip using emule , would i need i password , key license or something like that ?
See this topic, contains kepserver and medicine.
http://www.plc.net.ru/viewtopic.php?t=7 ... epserverex
regards - saludos- zenchek
Fortu
Post by Fortu »
Hi to all..
I'm havin' souch problems in the OFS installation.
I tried to use this serial:
serial: 21063301323
..but it doesn't works 'cause I can't clic on the "next" button of the nstallShield Wizard!!
:cry:
please..can someone tell me how to do???
Fortu
Post by Fortu »
solved the problem :D
serial: 21063301323
Thank you most!!
:D :D
leofarhan
IEC61850 Communication
Post by leofarhan »
Is there any Schneider OPC Server with which I can communicate IEDs & Schneider PLCs to my SCADA. Some one suggest me AXS4MMS OPC Server, if anyone have this, please upload. Or tell me how can I do so.
sami
Re: [KEY]: Key for Schneider OFS (OPC factory Server V3.31 L
Post by sami »
Hello Guys,
This is my first time on plcforum. Can anyone help me in obtaining the authorization code for ProWorx32. The details are as following
Code Entry Number: 289128956
Computer ID: 785083
I will highly appreciate a quick reply.
Regards
Sami
Serge_n
Post by Serge_n »
sami wrote:...
Computer ID: 785083
viewtopic.php?t=8485
MAGO1412
Post by MAGO1412 »
Hello to all.
I have tried to generate this keygen for OFS 3.31 L, but they me do not work...
It would be possible that someone might generate the code since it me does not work on having treated with the keygen and does not allow me to install the OFS:
ID PC: 8997373
SerialNumber Unity Pro: 1234 5678 999
Code of Entry to the PC Unity Pro: 236193672
Thanks.
vlad2006gr
TLXCDSUOFS33-it's OPC Factory Server V3.3 Small 1 Station - where did you get this? Please upload to rapidshare. Then we can help. You wrote:
I have tried to generate this keygen for OFS 3.31 L, but they me do not work ...
OFS 3.31 L - is the OPC Factory Server V3.3 Large.
And do not post a question in different positions.
xorman2k7
Post by xorman2k7 »
I know this is an old post, but could it be posible for any of you to upload again that UnityKeygen? I can't seem to find it anywhere
thanks
