[LINK]: BR automation studio AS2.5.3.28
другие контроллеры
zvocko
Post by zvocko »
[dead] :/66895528/au ... _2_5_3.001
[dead] :/66907455/au ... _2_5_3.002
[dead] :/66922746/au ... _2_5_3.003
[dead] :/66957996/au ... _2_5_3.004
[dead] :/66973806/au ... _2_5_3.005
[dead] :/66965552/au ... _2_5_3.crc
This is FULL trial ENGLISH version for 30 days.
After installation start it and it will ask for a CSID number.
Enter 42118LF339X and copy given SYSTEM CODE number.
Go to the BR registration web page:
http://www.br-automation.com/cps/rde/xc ... G_HTML.htm
Click on registration. Paste SYSTEM CODE number.
System will ask for a reason of registration (because it has been registrated for more than 130 times).
Select some reason (hard disk break or system reinstall) and it will give your registration number.
After that You can download service pack from BR site.
Mirror Bestsharing links:
http://www.bestsharing.com/files/qxafi3 ... 3.001.html
http://www.bestsharing.com/files/NBLNa3 ... 3.002.html
http://www.bestsharing.com/files/yHTefo ... 3.003.html
http://www.bestsharing.com/files/REuiR5 ... 3.004.html
http://www.bestsharing.com/files/7XIUk3 ... 3.005.html
http://www.bestsharing.com/files/3uqeL3 ... 3.crc.html
B&R ENGLISH HELP self extraction exe file:
http://www.bestsharing.com/files/MfHpWu ... 1.rar.html
http://www.bestsharing.com/files/Dsa4cn ... 2.rar.html
http://www.bestsharing.com/files/ApSXYy ... 3.rar.html
Copy all files to the same dir.
Launch Total Commander, navigate to dir, mark all files you downloaded and click Files->Combine Files... .
Thanks very much
Post by Thanks very much »
All OK. All worked.
Thanks from Little_Cat, niila,...
inwestor
Post by inwestor »
permanent anti angry solution for 2.5.3 english version is by a forum user for test.
for me it is not possible to make real test.
hope he will finish test this year.
lewis
Post by lewis »
I download it
but I could not install it
is there something wrong ?
crack_x01
Post by crack_x01 »
hi friend
serial is not work.please help me
inwestor
Post by inwestor »
requester has not finished test - it's a requester not a tester.
but solution is here :D :
AS 2.5.3.0028.SP06 and SP08
PG1.exe - 3.166.261 Bytes
2007.6.6.14
org
 000330C0 6A0068582C53006A0068C83E4300 E8DC
 000330D0 080C00 83C4188985DCF4FFFF8B8DDCF4
change to
 000330C0 6A0068582C53006A0068C83E4300 33C0
 000330D0 909099 83C4188985DCF4FFFF8B8DDCF4
peterfrick
Post by peterfrick »
inwestor Thanks for your work.
Can you please tell me the other download links of As 2.6 or 2.7.
Once again Thanks.
crack_x01
Post by crack_x01 »
inwestor wrote:requester has not finished test - it's a requester not a tester.
but solution is here :D : ....
How is it cracking?
bestregards
niila
Post by niila »
hi..
probably you must use a hex editor for change code
http://www.winhex.com/winhex/index-m.html
best regards
chinazhang
Post by chinazhang »
I download all five installed-package! I,m add '.rar' behind every package! but can't decompressed or un-zipped before installation! What should I do?
crack_x01
Post by crack_x01 »
hi inwestor
can you upload sp6 or sp8 ?
bestregards
onderatsan
Re: [LINK]: BR automation studio AS2.5.3.28
Post by onderatsan »
Links Died. Can You upload again?
FlashPT
Post by FlashPT »
please help ....
I need link to dwnl.
Regards
rkd47
Post by rkd47 »
Hello friend, can you help me? Do you still have the link for B&R Atomation Studio V2.5.3.28, I need this version.
