[?]: i need to have a event logging into Wincc
PLC_ITA
Post by PLC_ITA »
Hi friends, i need to have a event logging into Wincc.
Any operations and/or modification from the operator i need to trace
I haven't a idea how to do !
Anyone have a idea or suggest ?
Thank you
dante
Post by dante »
It's very easy. Assign a script to any button the operator can press; the script must run "on button down" for example. That script have to write (as APPEND) infos in a log file (like: date, hour, button number, logged user etc).
PLC_ITA
Post by PLC_ITA »
Hi, Mr Dante, I understand, but i want view this log, same alarm logging.
In every button i can add a script, but how i can do to write a string with data-hour-text ecc into a file compatible whit alarm logging or similar
thank you
dante
Post by dante »
If U want alarm logging, my first ideea is to assign an alarm bit for any event U want to trace and activate that bit with the button script.
PLC_ITA
Post by PLC_ITA »
Your idea, is a possible solution. For now i haven't another idea.
If is possible, is better to have a script into a pushbutton, which i write directly into alarm logging database , whitout have a bit every message, and relative text into alarm logging
do you know if is possible ?
Another question ?
do you know how PCS7 system realize the event logging ?
bye
dante
Post by dante »
Don't know if possible, I think not, but the "normal way" to log alarms and warnigs is to activate a bit, I think (not 100% sure) U can define & use internal tags (means that bits are not into the PLC, they are only WinCC internal).
Have no ideea about PCS.
dante
Post by dante »
...another point: you can define & use only one alarm (if you want to) for many buttons, so writing the text will be not so time consuming.
PLC_ITA
Post by PLC_ITA »
thanks Dante, for now i use your method.
Many thank again for your idea
Fabio
Galli
Post by Galli »
PLC_ITA wrote:thanks Dante, for now i use your method.
Fabio
Hi PLC_ITA ..
I'm still learning WinCC..
Can you post the sample script, - how to do it ..
Thank you..
