[?]: How to get password from S7 400 PLC ?
engineer888
I want download PLC program fro CPU of S7 400, but it has password.
I don't know password, because I need upgrade plc program.
Do you have a kind of software that can crack it .
Thank everybody !
Thank everybody !
bithu
Re: How to get password from S7 400 PLC ?
Want to open the protected block?
s7canopener can make it.
just click the link below,
viewtopic.php?t=6763&highlight=s7canopener
engineer888
I know how to open block.
I want download PLC program but not open block. beacuse I have no original program. Could you help me ?
dante
can U upload the program into your PC? If not, there is no way to modify it (or, only Siemens know how to do it); that case you have to ask the manufacturer for the program; after this you must compare the offline blocks with the online ones and ONLY if they are IDENTICAL you can proceed to perform a complete PLC reset and download the offline program.
engineer888
I have no backup original program
In fact, this project was made by another company, they didn't deliverly original program to end customer. If customer want make a little change, they must require supply company come to site. the price is very expensive , so the customer want crack password and change original program. Now , the problem I cann't download and upload it, I know a kind of way to do it. We can erase MMC card also password was deleted. But the original program were deleted at this time.
How to resolve it ??
engineer888
I cann't upload
I cann't upload, because it also need password. How to back up program from 400 MC card. I think it only was read by Siemens PG.
dante
Another ideeas:
Method 1:
IF U have a MC card (not MMC), try the following:
1. power off the PLC.
2. remove the MC-card
3. power the plc on
4. perform a PLC reset
5. switch PLC off
6. plug in the MC card
7. power the PLC on
8. perform again a reset (program from MC card will be loaded into the PLC)
Note: ALL data will be set to the initial values, so try this with another PLC and MC card, or, write down on the paper all actual machine parameters BEFORE doing this.
Method 2:
1. make sure you have a good backup battery
2. power off the PLC.
3. remove the MC-card
4. DO NO NOT power the plc on without the card!!!!
5. read the MC card on a Siemens PG
6. plug in the MC card back into the PLC
7. power the PLC on
Don't forget to GIVE A FEEDBACK on the forum. Many, many other guys have the same problem!
Method 1:
3. power the plc on
5. switch PLC off
7. power the PLC on
Method 2:
7. power the PLC on
frankw
executer
Re: [?]: How to get password from S7 400 PLC ?
So, please, does someone can provide a right way to get password from protected S7-400 PLC with MC Flash card?
jk1981
Please send me your email address in private messageamarillo wrote: Thu Nov 01, 2007 9:30 pm lol,
Give me the Memory Card file and I will retrieve the password for free .
Lone star
amarillo
smb
How can I get the password of Bin file of S7-400 MC flash memory?
Thx
Thx
kidsolo12
Which tool you use to read the bin file from MC Flash card?
