[?]: WinCC 6.2 server - Runs only in DEMO after upgrade
enraptured
Post by enraptured »
Help, Upgraded WinCC to 6.2 from 6.x. Server 64K with 512 archives with User Archives installed, but only runs in DEMO.
Complains of more than 512 archive tags.
I used the keys in Simatic_EKB_Install_2007_07_01 but it doesn't seem to work. Everything worked OK with earlier version of 6.x
Any thoughts, tips, suggestions?
Try Beta Key_install from link inside PLCSIM 5.4 http://plc.net.ru/viewtopic.php?t=6735
SIFCY9WTGX06001
enraptured
WinCC 6.2 in Demo after upgrade from 6.x
I did download that Beta, same thing. The WinCC Authorization information says:
SISLA9WRC40602 - WinCC Runtime+Configuration 64K Power TAgs 512 Archive Tags.
More than 512 archive tags were found. The "Archive" License is required.
I have installed the User Archive software & license and it shows up OK in the ALM. I've even uninstalled and reinstalled all of WinCC with both Premium Studio & the WinCC 6.x - WinCC 6.2 upgrade disk, no luck.
I've got the following installed:
WinCC RC, WinCC Server, WinCC User Archives and the normal communications stuff.
I actually purchased and paid for WinCC and the upgrade, its just I don't like to use "Upgrade" keys or software, its more maintenance and not as clean.
Install SIFCY9WTGX06001.EKB for 1500 Archive tags
This is Beta - see last keys in ALL KEYS or find key SIFCY9WTGX06001
[dead] :/64916549/Si ... 4_BETA.exe
enraptured
I used the wrong one, needed the count relative one. Thanks for the help.
Try SIFCY9WTGX06021 WINCC Arch 1500
[dead] :/65766297/Si ... 8_BETA.zip
include demo project with more 512 tags
need change project Computer name to your computer name
From C:\Program Files\SIEMENS\WINCC\Diagnose\License.Log
with SIFCY9WTGX06001
Demo mode wrote:10/28/2007 13:34:14 InitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WRC40602 | Text of License = WinCC RC (65536) | Relevant Limit = 0000000512 |
10/28/2007 13:34:14 Control Center - Demo Mode Runtime enabled -
10/28/2007 13:34:14 NoLicense RT | Name of License = SIFLA9WRC40602 | Text of License = WinCC RC (65536) | Exists = Yes | Limit Exceeded = Yes ,512 Archive Tags | Emergency License = No | TLG = 0000513 |
with SIFCY9WTGX06021
Work mode wrote:10/28/2007 15:23:50 InitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | NameForMessageBox = | Name of License = SIFCY9WTGX06021 | Text of License = WINCC Arch (1500) | Relevant Limit = 0000001500 |
