Hello!
I have a problem.
I forgot password for Touchsreen at BetoneMachine.
I have a SystemBackup.
Can anybody help?
[?]: Password for ProTool Touchsreen
alfred.eekhoorn
reymond_craig
The default password for Touchscreen MP370 is 100, if you are sure you have the existing downloaded program, you can take a look at first open your protool project then go to system - settings you can see what is the OP supervisor password. Try to used this password when you are promted on the touchscreen.
Hope this can help.
Warm regards,
Rey
Hope this can help.
Warm regards,
Rey
what TP do you have?
The pass is the one set on the ProTool project; the default value for this pass is 100 that means after a project download, the level 9 pass is 100; after this, you can change the pass from the TP and the old one is no longer valid.
If U loose that pass, the way to get the control back is to download again the project. To get into the download menu U must swich off the supply of the TP, the transfer button appears for short time after restoring the power. Note that downloading the project again will loose the receipes.
