Hello friends, i have only a little experience in CFC.
I want to move a word from ad DB to another DB when a bit is true in CFC
For example in S7 i use the follow sintax :
UN I0.0
SPB xxx
L DB10.DBW20
T DB20.DBW20
xxx:
In this case when Input I0.0 is false the word DB20.DBW20 is'nt overwrite and is possible to write for example, from a MP277
In CFC is not possible to do this because if i create a FC or FB i have always an out from the block and always owerwrite my word.
How i can do to resolve this problem ? what do you suggest ?
thank you
[?]: CFC problem
krcedinac
For example with the word it can be done like this:
Code for the Word to Real conversio function Conv_W_R is:
L #Word_IN
ITD
DTR
T #Out_data
OP_A block that passes real value when ti boolean input is on I think can be found in standard librarys.
You can think various ways to do it... this is just idea.
L #Word_IN
ITD
DTR
T #Out_data
