[?]What are the differences between WinCC and WinCC Flexible
vaiduakhu
Post by vaiduakhu »
Both are HMI softwares. So what are the differences?
See http://www.automation.siemens.com/hmi/h ... erview.htm
and
WinCC Flexible - panel oriented SCADA with no more 2048 tags
WinCC - PC oriented SCADA with max 4 000 000 tags
Galli
Post by Galli »
Can we instal WinCC Flexible 2007 on PC or not?
Can we install WinCC Flexible 2007 and WinCC 6.2 on the same PC or not?
All theese software are avalaible in plc.net.ru
Umencho
Post by Umencho »
hi
see here: http://plc.net.ru/viewtopic.php?t=2
you can always use search here :lol: :lol: :lol:
regardsu
umencho
Galli
Post by Galli »
I have WInCC Flexible 2007 & WInCC6.2 ..
All link download from plc.net.ru..
My question can I install both WinCC6.2 and WinCC Flexible 2007 on the same PC..
Because I want to try use WinCC Flexible 2007, scare compatibilty issue
with WinCC6.2 if install on the same computer..
ale_iks
Post by ale_iks »
Hi!
If you have smart enough PC (with 2Gb or more ram), you can do that.
Galli
Post by Galli »
ale_iks wrote:Hi!
Thank you..
I only have 1.5 GB ram...
I will buy another hard disk install another operating systems..
So many software here, with WinCC6.2, Intouch, Ifix, Citect in one
PC...
I use PCS7 7.0 with WinCC 6.2 and WinCC Flexible 2007 in one comp without problems because Flex have smart MS SQL witout conflict with MSSQL 2005 for WinCC.
