Hello friends
i need to show into a personal computer only 5-6 variable from cpu 315
I can use mpi or profibus opzional ethernet
I have already a cp 5612 inside a pc because i use this station for step S7
In normal operation i want to create a little application to read 5-6 variable from plc.
How can i use ??? Wincc 128 tag is very expansive.. */- 2000 € for use only 5-6 tag
what do you suggest for this problem ?
Thanks a lot..
[?]: Connect with PC without WinCC
OK, sorry for the delay...
Here's the link for the IOserver; note you DO NOT need a DAS server (will be needed only with IAS, wich is not the case); the IO server is really what you need; you have a .pdf document included; hope there is no need for lincence (as I remember).
The variabile format for Excel should be included in the .pdf
You only need to install the server and configure it for your comm card. After this, open an Exel sheet and insert into the cell a variabile with the correct format for accessing the server. That's all.
Good luck!
[dead] :/65711777/IOServer-S7.rar
pass: PeterAerts
Good luck!
pass: PeterAerts
