Request: YOKOGAWA CENTUM CS3000
fen
yokogaw cs3000
fen
cs3000 software revision 2 (R2)
this is a Yokogawa CENTUM CS 3000 R3.02.30
software installation, uses TotalComander mene File>Combine or hjsplit.exe to join all files in one iso file.
12 * 14 336 000 + 7 090 176
[dead] :/53987696/CE ... RE.iso.013
[dead] :/54060396/CE ... RE.iso.012
[dead] :/54055423/CE ... RE.iso.011
[dead] :/54051034/CE ... RE.iso.010
[dead] :/53994694/CE ... RE.iso.009
[dead] :/53991305/CE ... RE.iso.008
[dead] :/53986177/CE ... RE.iso.007
[dead] :/53982763/CE ... RE.iso.006
[dead] :/53979756/CE ... RE.iso.005
[dead] :/53977052/CE ... RE.iso.004
[dead] :/53839778/CE ... RE.iso.003
[dead] :/53534839/CE ... RE.iso.002
[dead] :/53525633/CE ... RE.iso.001
link for Hjsplit
[dead] :/53394202/hjsplit.zip
or 2 parts (55 555 555 + 52 463 467)
[dead] :/92550822/Ce ... .part1.rar
[dead] :/92550791/Ce ... .part2.rar
link for Hjsplit
utuh_garubuk
Tested and working.. Nice...
You can create and simulate only one (1) FCS and and more than one HIS in a single PC..
what You need..:
1. CS3000 Software Medium R3.x.xx (I think old version it's not function)
2. Cd Key in Flopy disk
How to install :
1. Insert Softwrae Medium cdrom.
2. Insert Cd key to drive A or flopy driver
3. Run setup at Software medium cdrom.
4. Follow the instruction, If ask ID.. just open cd key file"Revision.KCD" with notepad and you can find where the ID..
5. At installation proccess, program will ask for "next Cd key" or "next Software medium". just select "No" option.
6. After finish do not select operator keyboard and com port just skip it.
7. Installation finish, and restart.
How to use Simulation:
1.After PC restrat, you can see small icon intray ( you will find it)
2.Select "Start--> Program-->Yokogawa Centum-->System View"
3.Program opened and dialog box appear that you do not have Project .
4.Select yes to create project and follow the instruction..( read manual for creation project, FCS and HIS)
5. After project has created, you can beginning run simulation..
what You need..:
How to install :
af.naderi
Re: [LINK]: YOKOGAWA CENTUM CS3000
hi fen
thanks for your links. i 'm new in Yokogawa Softwares and want to download them, but your links:
can you reuload first links?
doesn't work. Next, these links are about 170MB totally, but second links are about 110MB. What 's the difference?[dead] :/53525633/CE ... RE.iso.001
CatCesar
Please reupload rapidshare's links
bat_on
On work the version is established CENTUM CS 3000 R3.02.30. Total size in archive 117 Мb
After training on courses I have last version: CENTUM CS3000 R3.08.50. Total size in archive 654 Мb:
Centum CS 3000 R3.08.50.part01.rar
Centum CS 3000 R3.08.50.part02.rar
Centum CS 3000 R3.08.50.part03.rar
Centum CS 3000 R3.08.50.part04.rar
Centum CS 3000 R3.08.50.part05.rar
Centum CS 3000 R3.08.50.part06.rar
Centum CS 3000 R3.08.50.part07.rar
scada2005
Hi bat_on,
do you have training documents?
bat_on
Educational documents in Russian lang:scada2005 wrote:Hi bat_on,
Инженерный курс по системе Centum CS3000. Код курса CKEG
VaHG
Hi to everyone
Очень надо, спасибо!
bat_on, can You upload these documents? That would be great!bat_on wrote: Educational documents in Russian lang:
kostyc
Hi!
Please help.
I need a YOKOGAWA FCN-FCJ Logic Designer.
Thanks.
Please help.
Thanks.
bat_on
VaHG, Был на работе, в тундре, выложить такой объем не мог.VaHG wrote:Hi to everyone
Есть белорусский сайт, где давали ознакомиться с русскоязычной документацией по CENTUM CS3000
http://belasusinc.com/belasusink.files/centum.html
На данный момент скачивание документации почему-то не доступно, выложу ту, что получил на курсах, документы практически идентичны:
rus_doc's Centum CS 3000
cemara
could anybody re-load cs3000 again please?
the above one is not active anymore.
![Link Dead [dead]](./images/smilies/Link_dead.gif)
Dechnarong
Re: Request: YOKOGAWA CENTUM CS3000
Could anybody share the link for download the CENTUM CS 3000 R 3.09 and key code?
Thank you.
Thank you.
Dechnarong
for whom interested.
Here are the link for dowload CENTUM CS 3000 R 3.09 and key code as below.
I got it in other forum.
Cadit : rott
Yokogawa CENTUM R30900
links:
1. http://www.datafilehost.com/d/f52e33c4
2. http://www.datafilehost.com/d/8fa83231
3. http://www.datafilehost.com/d/05774526
4. http://www.datafilehost.com/d/35f8980b
Cadit : rott
links:
sajid
while installing get Network error... "Network not Installed" how to resolve it.
thank you in advance.
ofeliosimango
hi i got it but i have problem to install I did descompress but from this file I got one file with floppy disc virtual and one image disc and onether file no setup with .exe to execute??? Halp pleasse!!!
mahdii3375
hi
download links are dead. can anybody send me download link of centum cs3000??
thanks
thanks
aminmirzaei741
Yokogawa CENTUM VP R6.08 or later
Could you help to upload the link for download the CENTUM VP R6.08 or later and tutorial file?
Thank you.
Thank you.
