[?]: PC ACCESS Connect with Visual Basic
zeta
Post by zeta »
Hai Friends...
I have any problem and can you help me???
1. How to connect Siemens PC ACCESS and Visual Basic...?? please explain it step by step!!
2. How to display data(value) in PC ACCESS to VB??
3. How to make a curve with data(value) handle in VB?? I will monitoring voltage every time and I will make a real time curve to describe it in VB...
Please give me explain and example...!!! :)
Thanks a lot
DimonS
Post by DimonS »
Delivery Release: PC Access V1.0, an OPC Server exclusively for S7-200's
Pre-configured sample projects
Build your application around a sample template that already contains a working project.
Samples for Visual Basic (Version 6.0), Simatic ProToolPro (Version 6.0 SP2), and Excel (Version 2000) are provided with the product. Use an OPC client that contains graphic images or create a custom Visual Basic interface in order to achieve a graphical OPC client.
http://support.automation.siemens.com/W ... 99&lang=en
DimonS
Post by DimonS »
