ethernet:cp343-1 v1.2 plc:s-7 300 cpu314-2dp i want connect pc and plc use ethernet protocol. plc ıp:140.80.0 2 pc ip:140.80.0.4 but no connected.
thanks.
[?]: How connect cp343-1 s-7 300 cpu314-2dp
Using the Ping command you can test whether an Ethernet connection can be set up between the PG/PC and the S7 controller or the CP343-1.
Open an MSDOS prompt ("Start > Run > cmd").
Enter the "ping" command and the IP address of the S7 controller - e.g. "ping 140.80.0.2".
The S7 controller is then accessible via Industrial Ethernet when reply messages are sent in response to the ping request.
amet
