[LINK]: CX-Supervisor v1.2
CX-One, CX programmer, NTST, Syswin ....
bladex
Post by bladex »
Hi!
I very need this software for Omron PLC, it`s Omron HMI ,visual system for this kind of PLC . Maybe somebody have this software.. upload plz .
greetings! CX- SUPERVISOR [OMRON]
gigi10
Re: CX-Supervisor
Post by gigi10 »
sunboy1234 wrote:installation was broken.please reupload.Thanks in advance
Instalation is all rigtht - if you install CX-Supervisor only. This instalation is without CX-Server instalation!!!
You find CX-Server for example on CX-One instalation here:
http://plc.net.ru/viewtopic.php?t=4924
...or download here
CX-Server 3.0
[dead] :/48166406/CXS30.rar
sunboy1234
install???????
Post by sunboy1234 »
I still don't install it. I may install other softwave,may not???
install step?????
I already have installed other more pc,but still many problems.
mech962784
Post by mech962784 »
Dear Sir
i am trying to use the licensing method included with cx-supervisor,
but still whenever i go to run a project it will give a message that a license cannot be found and no external communication will be active.
what shall i do?
flopez
token Omron
Post by flopez »
Hi mech962784
Use the license Token Omron functions 100%
[dead] :/88446523/OmronToken.rar
Flopez
mech962784
hi flopez
thanks for the reply
but which file i have to use the 6.img or the other one?
and is it possible to use this under windows xp?
because i am facing problem while using these with the xp
Best Regards
most
Post by most »
erase please
mech962784
Dea Most
thank you for your help but actually whenever i use the to token mover program and press button 1 for scan the A: drive for tokens i am receiving a system 16 bit error and an error in something called nvdm ?
i have tried this on two pc's with winxp sp2 and i am getting same results.
can you help me?
Олег
Post by Олег »
Try the program Floppy Image on other computer.
in Russian wrote:"Floppy Image" почему-то нормально работает не на всех компах, то есть не всегда может сделать полную копию дискеты.
Иногда бывают случаи что и с проверенной дискеты не удаётся установить ключ, из-за настроек компьютера.
Обычно без проблем всё проходит на свежеустановленной винде.
6_token.img---- 6 ключей
scs_12.img---- 12 ключей
образы и картинки с help делались на XP, наверно должно быть заметно по формам окна на картинках
ключи подходят к любой версии CX-Supervisor до 2.0
mech962784
Dear Олег
i have tried both of them on another computer,and same results i am acheiving,
can any body with a working floppy image send this image to us using the copy-star program.
Best Regards.
most
Post by most »
erase please
rator
cx supervisor
Post by rator »
hello, I try the token mover some times and don't work correctly, is there any clue to have a good image?
thanks for all1
Олег
Post by Олег »
I don't understand your problems.
You can try made diskette in other PC.
Не понимаю что за проблемы у вас с установкой ключей...
у меня например сделать ключ с помощью "fllopy image" первый раз получилось только на третьем компьютере, но мой домашний сейчас лепит их без проблем.
на всякий случай выложил свою коллекцию ключей
My keys collection
[dead] :/99931240/OMRON_key.rar
or for Russian http://narod.ru/disk/6763000/OMRON_key.rar
most
Post by most »
erase please
rator
ok
Post by rator »
thanks for all, I try to make the disk with 2 computers, one with w98 and the other with xp, I will try another
