[?-]: STEP7 is compatible with VISTA X64 ?
jonydarko
Post by jonydarko »
I have Vista X64, can any one help me to install Step7 5.3 with this system? :cry:
http://plctalk.net/qanda/showthread.php ... ight=Vista
bobdjones wrote:According to Siemens technical forums present versions of Step 7 are not compatible with Vista.
rataman
Post by rataman »
No siemens software works on 64-bit operating systems yet. Drivers issues.
WinCC v7.0 (and Step7) will be compatible with VISTA in January 2008
Masta2002
Post by Masta2002 »
CoMod wrote:WinCC v7.0 (and Step7) will be compatible with VISTA in January 2008
Where you got this info? Do you know if theres a new version for step7 or only a update for 5.4? for WinCC theres a new version it seems!
From Russian forum :
http://www.automation-drives.ru/forum/v ... 4122#24122
Юрченко Владимир, Siemens, Moscow wrote:Recently like WinCC V.6.2 has appeared, and it V.7.0 submit :-)
And if it is serious - in plans 7-th version WinCC in the first quarter of next year. From new opportunities I can tell only about support Vista (by then and other software "will be tightened" to new OS).
This information can be trusted, as half a year back it has named exact terms of output Flex 2007...
Юрченко Владимир Сименс Москва wrote:Недавно вроде WinCC V.6.2 появился, а им уж V.7.0 подавай :-)
А если серьезно - в планах 7-я версия WinCC в первом квартале следующего года. Из новых фичей могу сказать только о поддержке Vista (к тому времени и остальной софт "подтянется" к новой операционке).
Так что всему свое время.
Masta2002
Post by Masta2002 »
Thank you for this infos!
